toshiba satellite a500 nskae la-5381p rev 0.2
The Compal LA-5381P Rev 0.2 schematic, dated 2009-04-10, documents the NSKAE motherboard platform. This design is built around the AMD S1G3 CPU platform with an integrated RS880M or RS880MC GPU and an SB710 southbridge. System memory is provided by two 200-pin DDRII SO-DIMM slots supporting dual-channel architecture. The embedded controller is an ENE KB926 D3, and the audio subsystem is managed by an ALC272 codec with a TPA6017 amplifier. Networking is handled by a Realtek RTL8111D/8103E LAN controller. Storage connectivity includes a JMB380 card reader controller. Thermal management is monitored by an ADM1032ARMZ sensor. The charging circuit utilizes an SLG8SP626 IC, and HDMI CEC control is provided by an R5F211A4SP microcontroller. The BIOS is stored on a SPI ROM.
Q: What is the board number and revision of this schematic?
A: The board number is LA-5381P, revision 0.2.
A: The embedded controller is an ENE KB926 D3.
Q: What is the CPU platform and chipset configuration?
A: The platform is AMD S1G3 with an RS880M or RS880MC GPU and an SB710 southbridge.
Q: What type of memory does this motherboard support?
A: It supports DDRII memory via two 200-pin SO-DIMM slots in a dual-channel configuration.
Q: What audio codec and amplifier are used?
A: The audio codec is an ALC272, paired with a TPA6017 audio amplifier.
| Brand | Compal |
| Model | NSKAE |
| Board Number | LA-5381P |
| Revision | 0.2 |
| Date | 2009-04-10 |
| CPU Platform | AMD S1G3 |
| PCH / Southbridge | SB710 |
| GPU Type | RS880M / RS880MC |
| EC / KBC | ENE KB926 D3 |
| Audio Codec | ALC272 |
| BIOS / SPI Flash | SPI ROM |
| RAM Type | DDRII |
| RAM Quantity / Slots | 200pin DDRII-SO-DIMM X2 |
| LAN IC | RTL8111D/8103E |
| Card Reader IC | JMB380 |
| Thermal Sensor | ADM1032ARMZ |
| Charging IC | SLG8SP626 |
| HDMI CEC Controller | R5F211A4SP |
| Audio Amplifier | TPA6017 |
