toshiba satellite p200 israe ls-3711p nvidia vga board rev 0.2
This Compal LS-3711P VGA board schematic, revision 0.2 dated 2007-01-24, is designed for the nVIDIA G72MV/G73M GPU platform with a G73M configuration supporting 128M or 256M frame buffer. The graphics subsystem utilizes four DDR2 16M*16 memory chips from Samsung, model K4D553235F-GC2A, located at positions U8, U9, U12, and U13. The board features a PCI Express interface and includes an ADM1032ARMZ-2REEL thermal sensor for temperature monitoring. The block diagram details the connection between the GPU and the DDR2 frame buffer memory via control and data buses, as well as the PCI Express lanes and clock signals.
Q: What is the GPU platform used on this Compal LS-3711P board?
A: The board uses the nVIDIA G72MV/G73M GPU platform, specifically configured as G73M with 128M or 256M frame buffer.
Q: What type and configuration of memory is used for the frame buffer?
A: The frame buffer uses four Samsung K4D553235F-GC2A DDR2 16M*16 memory chips located at positions U8, U9, U12, and U13.
Q: What thermal sensor is used on this VGA board?
A: The board includes an ADM1032ARMZ-2REEL thermal sensor for monitoring temperature.
| Brand | Compal |
| Model | LS-3711P |
| Project Code | LS-3711P |
| Board Number | LS-3711P |
| Revision | 0.2 |
| Date | 2007-01-24 |
| CPU Platform | nVIDIA G72MV/G73M |
| GPU Type | nVIDIA G72MV/G73M |
| Graphics Architecture | G73M with 128M/256M Frame Buffer |
| RAM Type | DDR2 |
| RAM Architecture | 16M*16 |
| RAM Quantity / Slots | 4 chips (U8, U9, U12, U13) |
| Thermal Sensor | ADM1032ARMZ-2REEL |
