toshiba vskaa ls-9862p r05 20131203
This Compal LS-9862P motherboard schematic, revision 0.1, dated 2012/09/28, is a Compal Electronics, Inc. design. The board number is DA2000WU000. The PCB revision is 0.3. The schematic includes a power button and power LED interface, with a notice that the ON/OFF button has a pull-high resistance on the motherboard and the LED resistance is not on the motherboard. The document is classified as Compal Secret Data.
Q: What is the board number for this Compal LS-9862P motherboard?
A: The board number is DA2000WU000.
Q: What is the PCB revision for the Compal LS-9862P?
A: The PCB revision is 0.3.
| Brand | Compal |
| Model | LS-9862P |
| Board Number | DA2000WU000 |
| Revision | 0.1 |
| Date | 2012/09/28 |
| PCB Name | LS-9862P |
| PCB Revision | 0.3 |
