jeremyadams
Hi,Please I need the clear me file for this asus model X555ld rev 3.3 .it's original bios file delays for 30sec before displaying
Hi,sir after programming it with the clear me file you sent,it still display after 30sec.I need a good clear me file. Thanks.
Hi,sir after programming it with the clear me you sent,it didn't display but trips off after some time. Can you kindly recommend a good working file for the same board and make a clear me of it.Thanks.
If motherboard is DIS, can you send the graphic chip number?It doesn't have graphicsIf motherboard is DIS, can you send the graphic chip number?
jeremyadams , Vahab Hemmati , Salimeh Bolboli , user50343 , user39084 , Roollice , adham , teknikbilisim , ebubekir soyalp , Mbuch , Rxtx , banofils , sultan321 , lech388 , ilhanb , Electronica360 , aminebou
