File Request Yoga 260 LENOVO BIOS can't reprogram
roeeb
Hi,
Seems my bios chip on board is not working properly
Can I jut buy new unprogrammed chip and program it on board ?
How can I get Bios files ?
Thanks
Roee
roeeb
Hello, If your Bios IC was damaged, you can buy new one, then program the IC
Send the motherboard model, I'll send the Bios file
Hi this is Yoga 260 Lenovo,
Product 20FES1VK00
version SDK0J40697
Serial C1KS65V0195
I will buy cheap programmer from Aliexpress
is this ok ?
Thanks,
Roee
roeeb
Product 20FES1VK00
version SDK0J40697
Serial C1KS65V0195
is this ok ?
Thanks,
Roee
The Bios Update doesn't work it give
Authontication error, and I have tried everything, and this proccess works for another laptop like this
Is the data I gave enough ?
Salimeh Bolboli
To buy programmer device and Bios IC, it's better to ask your question from this link
We don't have Bios update! We send you dump file and you need to open laptop and remove Bios IC, then you should program it
with the file we send.
roeeb
yes I understand you send binary file
But how to program it? - with external programmer or inside laptop ?
If inside laptop how to perform it ?
Thanks,
Roee
roeeb
Thanks,
Roee
Ok understand that I solder new empty chip, and reprogram inside laptop, so I need some manager program that allows the programming, do you have it also? or I should have it inside my laptop ?
roeeb
Hi,
Can you send it ?
Thanks,
R
