Unfortunately, Hossein Asadolahi is not feeling well ( Because of Covid 19 ) and needs to rest. He will answer you after recovery. Thank you for your understandingHi, Laptop boots without a picture. I checked the voltage, they all look ok, only GFX_CORE is missing. Resistance on PL25 and PL26 about 6 Ohm. Is ISL95857 can be damaged? How can I confirm it?
6 ohm resistance is ok . gfx core is last voltage that maybe not be necessary to generate in some case , so i suggest you reprogram bios with another bios bin file and clear me .Hi, Laptop boots without a picture. I checked the voltage, they all look ok, only GFX_CORE is missing. Resistance on PL25 and PL26 about 6 Ohm. Is ISL95857 can be damaged? How can I confirm it?
program bios and ec with this file and replay result plzThank You for reply. I programmed the bios from https://dr-s.com/threads/lenovo-yoga-910-13ikb-glass-cyg50-nm-a901-bios.8682/#post-8685
but unfortunately there are no changes. What else could be causing the problem. What else can I measure?
iphone one , user57871 , user54562 , user61868 , sultan321 , user55941 , Rohit suthar , Sophonias Ethiopia , AndyTech , endurance albert , Dcomp , CZ027 , megaglobal12
