Run your repair shop like a pro – for just $10/month!
Finty keeps your repair business organized and efficient without breaking the bank. Explore live examples of tickets, tracking, invoices, and more.
💻 Live Demo 💲 Pricing 💬 Contact Support
Unlock Bios Password 6050a2930901-mb-a01 hp 830 g5 bios unlock
user60367
Toolbox
need help to unlock my bios.. thank you
  • hp back up.rar
that file is new and exact file for this model and should work
check it more
try this file
  • 830 G5 unpass.zip
user60367
Toolbox
001: 爱修
002: iFix iFix
003: Serial number: ,PCB V1.80,Boot V1.00
004: >------------------------------------OK---------------------------------------<
005: Read timeout.
006: Retrying ...
007: Align to the bottom of ZIF,disable placed at random function.
008: Chip pins contact is detected OK.
009: Auto identified 21 ID is match with the partnumber.
010: The currently selected:W25Q256FV@WSON8 8X6, capacity: 256Mbits, 32Mbytes.
011: iFix 爱修网RT809F教程与软件会员注册 技术求助区 专业液晶维修 编程器官方网站RT809F使用教程 —— RT809F离线写8脚25芯片(主板BIOS、显卡BIOS、硬盘固件芯片等) - Powered by Discuz!
012: >------------------------------------OK---------------------------------------<
013: C:\USERS\LENOVO\DESKTOP\830 G5 UNPASS.BIN
014: File has been loaded, checksum: 16bits_0x6B27 £¬32bits_0x8AF16B27 :
015: Read timeout.
016: Retrying ...
017: Align to the bottom of ZIF,disable placed at random function.
018: Chip pins contact is detected OK.
019: Chip ID verification OK.
020: UniqueID:0x2F492C9F360868DB
021: Start writing chip......
022: Auto erasing...
023: This type of chip capacity is big, so erase time is take longer, please be patient!
024: Erase successful£¬Elapsed time£º49.02 seconds¡£
025: Start writing...
026: Write successful£¬Elapsed time£º27.67 seconds¡£
027: Auto verifying...
028: Verification successful£¬Elapsed time£º21.62 seconds¡£
029: Status Register-1 : 0x0 , Status Register-2 : 0x2 .
030: Elapsed time: 98.77 seconds£¬average speed of 679425 bytes/sec.
031: >------------------------------------OK---------------------------------------<
still the same.. :cry::cry:
try this one
  • 830 G5_New.zip
user60367
Toolbox
try this one
005: Align to the bottom of ZIF,disable placed at random function.
006: Chip pins contact is detected OK.
007: Auto identified 21 ID is match with the partnumber.
008: The currently selected:W25Q256FV@WSON8 8X6, capacity: 256Mbits, 32Mbytes.
009: iFix 爱修网RT809F教程与软件会员注册 技术求助区 专业液晶维修 编程器官方网站RT809F使用教程 —— RT809F离线写8脚25芯片(主板BIOS、显卡BIOS、硬盘固件芯片等) - Powered by Discuz!
010: >------------------------------------OK---------------------------------------<
011: C:\USERS\LENOVO\DESKTOP\DR BIOS FILE\830 G5_NEW.BIN
012: File has been loaded, checksum: 16bits_0x957B £¬32bits_0x8ABD957B :
013: Align to the bottom of ZIF,disable placed at random function.
014: Chip pins contact is detected OK.
015: Chip ID verification OK.
016: UniqueID:0x2F492C9F360868DB
017: Start writing chip......
018: Auto erasing...
019: This type of chip capacity is big, so erase time is take longer, please be patient!
020: Erase successful£¬Elapsed time£º45.98 seconds¡£
021: Start writing...
022: Write successful£¬Elapsed time£º27.49 seconds¡£
023: Auto verifying...
024: Verification successful£¬Elapsed time£º21.75 seconds¡£
025: Status Register-1 : 0x0 , Status Register-2 : 0x2 .
026: Elapsed time: 95.34 seconds£¬average speed of 703897 bytes/sec.
also the same. auto on then blinking whte and orange light in charging light. the power lights on, in button. the fan run high speed..
even i force off it will on automaticaly.i will try again tommorow.. thank you admins and staffs.
hi
if you programed bios with old backup and system still have problem in booting , i guess system have different problem and bios file don't have problem
you must check the voltages and other things .
example : check the components around the bios ic .
Since the device does not turn off , i guess io has a problem . maybe when the system is on you have Screwed up ;)
user60367
Toolbox
hi
thank you.. i will check it now.. let me show you the reading in oscilloscope.. i know im out of the topic in the section.. im sorry for that.. thank you for your consideration.
you are welcome
good luck
