Technical Support 820-3437 Macbook Air 1466
Patrick Ribbsaeter
Lagadatorumea
Hi master, this resistor R7005 keeps blowing up. What could be the issue?
Missing Greenlight on the charger. The customer said its been water damaged. I cleaned up some corrosion but first need to fix the green light.
Patrick Ribbsaeter
Lagadatorumea
I manage to fix the short... Post details here. Only missing green light now on the charger
I removed C7090 and without the cap it shows now = 0.430
replaced with another cap on C7090, and not it shows = 0.399 and now I have a green light on the charger with my DC Supply but not normal charger.
PPBUS_G3H is now 8.1v only
you must work on isl6259 . ex : is there an adapter voltage behind the q7130?
Patrick Ribbsaeter
Lagadatorumea
I changed the SMC and now I have Greenlight/orangelight on the charger with 8.5v... It was not the ISL6259... Usually, 8.1v on PPBUS_G3H is an SMC failure from experience. So will check all other voltages now. and post them here...
