acer aspire 3100 compal_la-3121p_rev1.0 schematic
acer aspire 3100=1=compal_la-3121p_rev1.0.pdf
The Compal LA-3121P motherboard, documented under project code HCW51 with document number 401411 and revision 1.0 dated 2006/04/27, is built around the AMD/Sempron CPU platform paired with an ATI-RS485MC GPU and an ATI-SB460 southbridge. System management is handled by an ENE KB910 EC/KBC controller. Audio is provided by a Realtek ALC883 codec, while networking is supported by a Realtek RTL8100CL LAN IC. Memory architecture consists of two DDRII SO-DIMM slots configured for dual-channel operation. The board incorporates an ICS951462 clock generator, an ADM1032AR thermal sensor, and a VT6311SA card reader controller.
A: The EC/KBC controller is an ENE KB910.
Q: What is the audio codec on this motherboard?
A: The audio codec is a Realtek ALC883.
A: The LAN IC is a Realtek RTL8100CL.
A: The motherboard supports DDRII memory in a dual-channel architecture using two SO-DIMM slots.
| Project Code | HCW51 |
| Board Number | LA-3121P |
| Document Number | 401411 |
| Date | 2006/04/27 |
| CPU Platform | AMD/Sempron |
| PCH / Southbridge | ATI-SB460 |
| GPU Type | ATI-RS485MC |
| EC / KBC | ENE KB910 |
| Audio Codec | ALC883 |
| LAN IC | RTL8100CL |
| RAM Type | DDRII |
| Thermal Sensor | ADM1032AR |
| Card Reader IC | VT6311SA |
| Clock Generator | ICS951462 |
