acer aspire 3100 compal_la-3151p_rev0.3 schematic
acer aspire 3290=1=wistron_ag1_alviso_rev01.pdf
This Wistron AG1 (Alviso) motherboard, project code 91.4G301.001 and board number 05223-01, is built around the Intel 910GML platform with an ICH6-M southbridge, supporting a Dothan CPU. The system BIOS is stored on a 4M BIT PM39LV040-70JCE flash IC. System management is handled by the ENE KB3910 EC/KBC. Audio is provided by a Realtek ALC655 codec, and networking by a Realtek RTL8110CL LAN controller. The board supports DDR II memory at 400 MHz. Power management is handled by a combination of ICs including the ISL6255 charger, TPS51120 and TPS51100DGQ system DC/DC converters, ISL6227 for additional rails, and ISL6218CV-T for CPU core voltage. The clocking solution is provided by an IDT CV125 generator.
A: The BIOS flash IC is a PM39LV040-70JCE with a capacity of 4M BITS.
A: The embedded controller/keyboard controller is an ENE KB3910.
A: The charging IC is an ISL6255.
| Project Code | 91.4G301.001 |
| Board Number | 05223-01 |
| Date | Tuesday, November 01, 2005 |
| CPU Platform | Intel 910GML |
| CPU Model | Dothan |
| PCH / Southbridge | ICH6-M |
| EC / KBC | ENE KB3910 |
| Audio Codec | ALC655 |
| BIOS / SPI Flash | PM39LV040-70JCE |
| BIOS Flash Capacity | 4M BITS |
| Charging IC | ISL6255 |
| Power IC(s) | TPS51120, TPS51100DGQ, ISL6227, ISL6218CV-T |
| RAM Type | DDR II |
| RAM Architecture | 400 MHz |
| LAN IC | RTL8110CL |
| WiFi / WLAN IC | Mini-PCI 802.11A/B/G |
| Clock Generator | IDT CV125 |
91.4G301.001
05223-01
910GML
Dothan
CPU Model
ICH6
KB3910
ALC655
PM39LV040-70JCE
BIOS / EC Flash
ISL6255
ISL6218CV-T
ISL6227
TPS51100DGQ
TPS51120
DDR2
RTL8110CL
CV125
Clock Generator
91.4G301.001
05223-01
910GML
Dothan
CPU Model
ICH6
KB3910
ALC655
PM39LV040-70JCE
BIOS / EC Flash
ISL6255
ISL6218CV-T
ISL6227
TPS51100DGQ
TPS51120
DDR2
RTL8110CL
CV125
Clock Generator
