acer aspire 5100_5110 compal_la-3121p_rev1.0 schematic
acer aspire 5100_5110=1=compal_la-3121p_rev1.0.pdf
This Compal LA-3121P motherboard, documented under project code HCW51, is built around an AMD Sempron CPU platform paired with an ATI-RS485MC northbridge and ATI-SB460 southbridge. The system is managed by an ENE KB910 embedded controller. Audio is handled by a Realtek ALC883 codec, while networking is provided by a Realtek RTL8100CL LAN IC. A VIA VT6311SA controller manages the card reader interface, and thermal monitoring is performed by an ADM1032A sensor. Clock generation is handled by an ICS951462. Memory configuration supports two DDRII SO-DIMM modules in dual-channel architecture.
Q: What embedded controller is used on this motherboard?
A: The motherboard uses an ENE KB910 EC/KBC.
A: The audio codec is a Realtek ALC883.
A: The LAN controller is a Realtek RTL8100CL.
A: This motherboard supports DDRII memory in a dual-channel architecture with two SO-DIMM slots.
| Model | LA-3121P |
| Project Code | HCW51 |
| Board Number | LA-3121P |
| Date | 2006/04/27 |
| Document Number | 401411 |
| CPU Platform | AMD/Sempron |
| PCH / Southbridge | ATI-SB460 |
| GPU Type | ATI-RS485MC |
| EC / KBC | ENE KB910 |
| Audio Codec | ALC883 |
| LAN IC | RTL8100CL |
| Card Reader IC | VT6311SA |
| Thermal Sensor | ADM1032A |
| Clock Generator | ICS951462 |
| RAM Type | DDRII |
