Schematic acer aspire 5335 5735z cathedral peak2 sb 08219-sb 4k801 schematic
acer_aspire_5335_5735z cathedral_peak2_sb_08219-sb_4k801 schematic
acer_aspire_5335_5735z_cathedral_peak2_sb_08219-sb_4k801.pdf
BrandWistron Corporation
ModelCathedral Peak II
Project Code91.4K801.001
Board Number48.4K801.0SB
Revision08219-SB
DateFriday, June 20, 2008
Document NumberA3143
CPU PlatformMobile CPU Cantiga
CPU ModelPenryn 479
PCH / SouthbridgeICH9M
GPU TypeIntegrated Graphics
EC / KBCENE KB3310
Audio CodecALC268
BIOS / SPI FlashWinbond W25X16
BIOS Flash Exact ModelW25X16
BIOS Flash Capacity16M Bits
Charging ICBQ24745
Power IC(s)ISL6263, TPS51125, TPS51124, ISL6266A
RAM TypeDDR2
RAM ArchitectureDDR2 DIMM1, DDR2 DIMM2
RAM Quantity / Slots2
Card Reader ICRealtek RTS5158E
LAN IC88E8071
WiFi / WLAN ICKedron 88E8071
The Wistron Cathedral Peak II motherboard, documented under project code 91.4K801.001 and board number 48.4K801.0SB revision 08219-SB, is built around the Mobile CPU Cantiga platform supporting a Penryn 479 processor. The system is powered by an ICH9M southbridge and features integrated graphics. The BIOS is stored on a Winbond W25X16 16M Bits SPI flash. System management is handled by an ENE KB3310 EC/KBC. Memory configuration consists of two DDR2 DIMM slots. The charging circuit is managed by a BQ24745 IC, with power regulation provided by ISL6263, TPS51125, TPS51124, and ISL6266A controllers. Integrated audio is delivered via an ALC268 codec. Networking capabilities include a Kedron 88E8071 LAN IC and a Realtek RTS5158E card reader controller.
A: The BIOS is stored on a Winbond W25X16 16M Bits SPI flash.
A: The system uses an ENE KB3310 EC/KBC.
A: The motherboard supports two DDR2 DIMM slots.
A: The charging circuit is managed by a BQ24745 IC.
  • Acer_Aspire_5335_5735Z=1=Cathedral_peak2_sb_08219-SB_4K801.zip
