Schematic acer aspire 5950-5950g ls-6935p rev 1.0 touch pad board schematic
compal ls-6935p rev 1.0 touch pad board.pdf
BrandCompal
ModelLS-6935P Touch Pad Board
Board NumberLS-6935P
Revision1.0
Date2010-10-22
Document NumberLS-6935P
This document is the Compal LS-6935P Touch Pad Board schematic, revision 1.0, dated 2010-10-22. The board is a proprietary design by Compal Electronics, Inc. and is classified as Compal Secret Data. The schematic includes a gold finger connector (JP1) and multiple tactile switches (SW1, SW2, SW3, SW4) identified as EVQPLHA15_4P and COMP_SW XRE094PVBINB1-2-12-E-7025A NOBLE. ESD protection is provided by diodes D1 and D2, model PJSOT05C in SOT23-3 packages. The board also features multiple mounting holes (H1, H2, H3, H4) and ferrite beads (FD1, FD2, FD3, FD4). The PCB identifier is LS-6935P_PCBDA40000WR00.
Q: What is the board number and revision of this touch pad board?
A: The board number is LS-6935P, revision 1.0.
Q: What is the document date for this schematic?
A: The schematic date is 2010-10-22.
Q: What tactile switches are used on this board?
A: The board uses EVQPLHA15_4P switches (SW1, SW2, SW4) and a COMP_SW XRE094PVBINB1-2-12-E-7025A NOBLE switch (SW3).
  • Acer Aspire 5950-5950G=1=LS-6935P Rev 1.0 Touch Pad Board.zip
