acer aspire 7750_7750g compal_la-6911p_rev0.3 schematic
acer aspire 7750_7750g=1=compal_la-6911p_rev0.3.pdf
This Compal LA-6911P motherboard, designated MB A6911, is designed for the P7YE0/P7YH0/P7YS0 model series. The platform is built around an Intel Sandy Bridge processor in an rPGA988B socket paired with a Cougar Point-M PCH. Graphics are handled by an ATI Seymour/Whistler/Granville discrete GPU. The system memory architecture consists of two 204-pin DDRIII SO-DIMM slots supporting two DIMMs per channel. The embedded controller is an ENE KB930, and the audio codec is an ALC271X/277X. A single SPI ROM is used for BIOS storage. Networking is provided by an AR8151/8152 Gigabit Ethernet controller, and a RTS5138 card reader IC is present.
A: The board number is MB A6911, and the project code is LA-6911P.
A: The embedded controller is an ENE KB930.
A: The motherboard uses a single SPI ROM for BIOS storage.
A: The motherboard supports two 204-pin DDRIII SO-DIMM slots with a Two Dimm Per Channel architecture.
| Model | P7YE0/P7YH0/P7YS0 |
| Project Code | LA-6911P |
| Board Number | MB A6911 |
| Revision | 0.3 |
| Date | 2010-11-01 |
| CPU Platform | Intel Sandy Bridge |
| CPU Socket | rPGA988B |
| PCH / Southbridge | Cougar Point-M |
| GPU Type | ATI Seymour/Whistler/Granville |
| EC / KBC | ENE KB930 |
| Audio Codec | ALC271X/277X |
| BIOS / SPI Flash | SPI ROM x1 |
| RAM Type | DDRIII |
| RAM Architecture | Two Dimm Per Channel |
| RAM Quantity / Slots | 204pin DDRIII-SO-DIMM X2 |
| Card Reader IC | RTS5138 |
| LAN IC | AR8151/8152 |
| Document Number | 4019A9B |
