acer aspire e5-471g v3-472p quanta zq0 rev 3a schematic 1
The Quanta Computer Inc. ZQ0 project, board number 3A146, is a Brodwell ULT 15W platform featuring an integrated GT3 IMC MCP 1168-pin GPU. The system utilizes dual-channel DDR3L-SODIMM memory across channels CHA and CHB, supporting 1066/1333/1600 MHz. The BIOS/SPI flash configuration is 8M+4M. The embedded controller is an IT8587, and the audio codec is an ALC283. Power management is handled by a BQ24737RGR battery charger and multiple regulators including TPS54318RTER, TPS51211DSCR, TPS51216RUKR, TPS51624RSM, TPS51225RUKR, and UP1658RQKF. Networking is provided by a Realtek RTL8111 LAN IC and a WLAN+BT module. The card reader controller is a GL843L, and the HDMI level shifter is an ITE6513.
Q: What is the BIOS/SPI flash configuration on this motherboard?
A: The BIOS/SPI flash configuration is 8M+4M.
A: The embedded controller is an IT8587.
A: The charging IC is a BQ24737RGR, and the architecture is a battery charger.
A: The memory is dual-channel DDR3L-SODIMM across channels CHA and CHB, supporting 1066/1333/1600 MHz.
| Project Code | ZQ0 |
| Board Number | 3A146 |
| Revision | ZQ0 |
| Date | Monday, April 07, 2014 |
| CPU Platform | BRODWELL ULT 15W |
| GPU Type | iGPU |
| Graphics Architecture | GT3 IMC MCP 1168 pins |
| EC / KBC | IT8587 |
| Audio Codec | ALC283 |
| BIOS / SPI Flash | 8M+4M |
| BIOS Flash Capacity | 8M+4M |
| Charging IC | BQ24737RGR |
| Charger Architecture | Batery Charger |
| Power IC(s) | TPS54318RTER, TPS51211DSCR, TPS51216RUKR, TPS51624RSM, TPS51225RUKR, UP1658RQKF |
| RAM Type | DDR3L-SODIMM |
| RAM Architecture | Dual Channel DDR III |
| RAM Quantity / Slots | CHA, CHB |
| Card Reader IC | GL843L |
| LAN IC | RTL8111 |
| WiFi / WLAN IC | WLAN+BT |
| HDMI Level Shifter | ITE6513 |
ZQ0
3A146
BRODWELL ULT 15W
iGPU
IT8587
ALC283
BQ24737RGR
TPS51211DSCR
TPS51216RUKR
TPS51225RUKR
TPS51624RSM
TPS54318RTER
UP1658RQKF
DDR3L-SODIMM
GL843L
RTL8111
WLAN / BT
ITE6513
ZQ0
3A146
BRODWELL ULT 15W
iGPU
IT8587
ALC283
BQ24737RGR
TPS51211DSCR
TPS51216RUKR
TPS51225RUKR
TPS51624RSM
TPS54318RTER
UP1658RQKF
DDR3L-SODIMM
GL843L
RTL8111
WLAN / BT
ITE6513
