acer aspire m3-581_m3-581t_m3-581tg pegatron_ma50_rev1.0 schematic
acer aspire m3-581_m3-581t_m3-581tg=1=pegatron_ma50_rev1.0.pdf
The MA50 Ultrabook platform by Joyoung_Chianhg, revision 1.0 dated February 13, 2012, is built around an Intel Sandy Bridge CPU paired with a Panther Point PCH. Graphics processing is handled by an nVidia N13PGL GPU with dedicated VRAM. System management is controlled by an NPCE795L EC/KBC. Audio is provided by an ALC271 Azalia codec. Memory configuration consists of two DDR3 SO-DIMM slots. Networking capabilities include a Broadcom BCM57780 GigaLAN controller and a WLAN + BT MiniCard interface. Storage connectivity supports SATA HDD, SATA ODD, and mSATA SSD. A Realtek RTS5209 card reader is integrated. The charging architecture is specified as Charger(4M+2M). The system also features USB 3.0 ports and an HDMI output.
A: The EC/KBC is an NPCE795L.
Q: What is the GPU configuration on this motherboard?
A: The GPU is an nVidia N13PGL with dedicated VRAM.
A: The audio codec is an ALC271 Azalia Codec.
A: The LAN IC is a Broadcom BCM57780 GigaLAN controller.
Q: What card reader IC is used on this motherboard?
A: The card reader IC is a Realtek RTS5209.
| Brand | Joyoung_Chianhg |
| Project Name | MA50 |
| Date | Monday, February 13, 2012 |
| CPU Platform | Sandy Bridge |
| PCH / Southbridge | Panther Point |
| GPU Type | nVidia N13PGL |
| EC / KBC | NPCE795L |
| Audio Codec | ALC271 |
| RAM Type | DDR3 |
| RAM Architecture | DDR3 SO-DIMM |
| Card Reader IC | Realtek RTS5209 |
| LAN IC | Broadcom BCM57780 |
| WiFi / WLAN IC | WLAN + BT |
| Charger Architecture | Charger(4M+2M) |
