acer aspire v3 372 wistron ba30 mihawk sl 13 15208-3 kabylake
The Wistron Mihawk MB-3 motherboard, documented under project code Mihawk SL 13 with board number 4PD06J010001 and revision -3, is built around the Intel KBL lake U platform featuring a SKYLAKE-U-GP CPU. The system utilizes DDR3L 1333/1600 memory across two channels. Graphics are handled by integrated UMA architecture rated at 15W. The embedded controller is an NPCT650, and the audio codec is an ALC255. The BIOS is stored on an 8MB SPI flash IC. Power management is handled by a combination of ICs including the RT6575, ISL95857HRTZ-T-GP, RT8231AGQW-GP, and RT8068AZQWID-GP. The charging subsystem uses an HPA02224 charger IC. Networking is provided by a Realtek RTL8111G(S) LAN controller and a WLAN + BT + WIGIG module. The card reader is an RTS5170, and HDMI 1.4b level shifting is supported. USB hub functionality is managed by TPS2544 and TPS25810 controllers.
Q: What BIOS IC is used on this motherboard?
A: The motherboard uses an 8MB SPI Flash IC for BIOS storage.
A: The embedded controller is an NPCT650.
Q: What is the charging architecture of this motherboard?
A: The charging subsystem is based on an HPA02224 charger IC.
Q: What is the graphics configuration of this motherboard?
A: The motherboard uses integrated UMA graphics rated at 15W.
| Brand | Wistron |
| Model | Mihawk MB-3 |
| Project Code | Mihawk SL 13 |
| Board Number | 4PD06J010001 |
| Revision | -3 |
| Date | Tuesday, June 06, 2017 |
| Document Number | A31105 |
| CPU Platform | KBL lake U (Intel CPU) |
| CPU Model | SKYLAKE-U-GP |
| EC / KBC | NPCT650 |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | 8MB SPI Flash |
| Charging IC | HPA02224 |
| Charger Architecture | HPA02224 CHARGER |
| Power IC(s) | RT6575, ISL95857HRTZ-T-GP, RT8231AGQW-GP, RT8068AZQWID-GP, RT8231AGQW-GP |
| RAM Type | DDR3L 1333/1600 |
| RAM Architecture | Channel A, Channel B |
| Card Reader IC | RTS5170 |
| LAN IC | RTL8111G(S) |
| WiFi / WLAN IC | WLAN + BT + WIGIG PCIe / USB2.0 |
| HDMI Level Shifter | HDMI 1.4b |
| GPU Type | UMA |
| Graphics Architecture | 15W (UMA) |
| USB Hub IC | TPS2544, TPS25810 |
4PD06J010001
Kaby Lake
SKYLAKE-U-GP
CPU Model
NPCT650
ALC255
HPA02224
ISL95857HRTZ-T-GP
RT6575
RT8068AZQWID-GP
RT8231AGQW-GP
DDR3L
RTS5170
RTL8111G
USB2.0
15W (UMA)
TPS2544
TPS25810
4PD06J010001
Kaby Lake
SKYLAKE-U-GP
CPU Model
NPCT650
ALC255
HPA02224
ISL95857HRTZ-T-GP
RT6575
RT8068AZQWID-GP
RT8231AGQW-GP
DDR3L
RTS5170
RTL8111G
USB2.0
15W (UMA)
TPS2544
TPS25810
