acer aspire v3-372 wistron mihawk sl 13 15208-2 1
The Wistron Mihawk MB, revision -2, is a Skylake U GT2e 15/28W UMA platform motherboard with document number A31, dated August 10, 2015. The project code is Mihawk SL 13 --> 4PD06J010001, and the PCB number is 15208. The system uses DDR3L 1333/1600 memory across two channels and integrates an ALC255 audio codec. The EC/KBC is an ENE9028 or ENE9038, and the BIOS is stored on an 8MB SPI flash. Power management is handled by an HPA02224 charger and multiple regulators including the RT6575, ISL95857HRTZ-T-GP, RT8231AGQW-GP, and RT8068AZQWID-GP. Networking is provided by an RTL8111G(S) LAN controller and a WLAN + BT + WIGIG module. The motherboard also features an RTS5170 card reader, a TPS2544 USB hub, a TPS25810 HDMI level shifter, and an NPCT650 thermal sensor.
Q: What EC/KBC controllers are used on this motherboard?
A: The motherboard uses either an ENE9028 or ENE9038 EC/KBC controller.
A: The BIOS is stored on an 8MB SPI flash IC.
Q: What is the charging architecture?
A: The charging architecture is based on the HPA02224 charger IC.
A: The motherboard supports DDR3L 1333/1600 memory across two channels, Channel A and Channel B.
Technical data structured and
| Brand | Wistron |
| Model | Mihawk MB |
| Project Code | Mihawk SL 13 --> 4PD06J010001 |
| Board Number | Mihawk MB |
| Revision | -2 |
| Date | Monday, August 10, 2015 |
| Document Number | A31 |
| CPU Platform | Skylake U GT2e 15/28W (UMA) |
| EC / KBC | ENE9028, ENE9038 |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | 8MB SPI Flash |
| Charging IC | HPA02224 |
| Charger Architecture | HPA02224 CHARGER |
| Power IC(s) | RT6575, ISL95857HRTZ-T-GP, RT8231AGQW-GP, RT8068AZQWID-GP |
| RAM Type | DDR3L 1333/1600 |
| RAM Architecture | DDR3L 1333/1600 Channel A, DDR3L 1333/1600 Channel B |
| LAN IC | RTL8111G(S) |
| WiFi / WLAN IC | WLAN + BT + WIGIG PCIe / USB2.0 |
| Card Reader IC | RTS5170 |
| USB Hub IC | TPS2544 |
| HDMI Level Shifter | TPS25810 |
| GPU Type | Skylake U GT2e 15/28W (UMA) |
| Graphics Architecture | UMA |
| PCH / Southbridge | SKL PCH-LP |
| PCB Number | 15208 |
| CPU Model | SKYLAKE-U-GP |
| Thermal Sensor | NPCT650 |
4PD06J010001
Skylake-U
UMA
ENE9028
ENE9038
ALC255
HPA02224
ISL95857HRTZ-T-GP
RT6575
RT8068AZQWID-GP
RT8231AGQW-GP
DDR3L
RTL8111G
USB2.0
RTS5170
TPS2544
TPS25810
28W
Skylake U GT2e 15
UMA
15208
SKYLAKE-U-GP
CPU Model
NPCT650
4PD06J010001
Skylake-U
UMA
ENE9028
ENE9038
ALC255
HPA02224
ISL95857HRTZ-T-GP
RT6575
RT8068AZQWID-GP
RT8231AGQW-GP
DDR3L
RTL8111G
USB2.0
RTS5170
TPS2544
TPS25810
28W
Skylake U GT2e 15
UMA
15208
SKYLAKE-U-GP
CPU Model
NPCT650
