Schematic acer aspire v5-531 v5-571 wistron petra uma schematic
BrandWistron
ModelPetra Uma-1
Project Code91.4VM01.001
Board Number11324
Revision-1
DateWednesday, February 22, 2012
Document NumberA31103
CPU PlatformIvy Bridge
PCH / SouthbridgeIntel PCH (Panther Point HM70/77)
GPU TypeUMA
Graphics ArchitectureIntel CPU 17W/GT2
EC / KBCNPCE885P28
Audio CodecALC271X
BIOS / SPI FlashSPI Flash ROM 8MB
BIOS Flash Capacity8MB
Charging ICBQ24727
Charger ArchitectureBQ24727 INPUTS DCBATOUT
Power IC(s)RT8223MGQW, ISL95836HRTZ, TPS51218DSCR, RT8207LGQW, RT9025-25ZSP, G978
RAM TypeDDRIII
RAM ArchitectureDDRIII 1600/1333, DDRIII 1333/1600
RAM Quantity / Slots2
LAN ICRTL8411
WiFi / WLAN IC802.11a/b/g
Card Reader ICRTL8411
USB Hub ICRTL8411
Thermal SensorNCT7718W
PCB Number48.4VM02.011
The Wistron Petra Uma-1 motherboard (Project Code 91.4VM01.001, Board Number 11324, Revision -1) is an Intel Ivy Bridge UMA platform paired with an Intel Panther Point PCH (HM70/77). The system memory architecture consists of two DDRIII SO-DIMM slots supporting DDRIII 1600/1333 and DDRIII 1333/1600. The embedded controller is an NPCE885P28, and the audio codec is an ALC271X. The SPI flash ROM is an 8MB device. Power management is handled by a BQ24727 charger IC with DCBATOUT input architecture, alongside multiple system DC/DC converters including ISL95836HRTZ, TPS51218DSCR, RT8207LGQW, RT9025-25ZSP, and G978. The LAN, card reader, and USB hub functions are integrated into an RTL8411 controller. Thermal monitoring is provided by an NCT7718W sensor. The PCB number is 48.4VM02.011.
Q: What is the EC/KBC used on this motherboard?
A: The embedded controller is an NPCE885P28.
A: The SPI flash ROM is 8MB.
Q: What is the charging IC and architecture on this motherboard?
A: The charging IC is a BQ24727 with DCBATOUT input architecture.
Q: What is the graphics configuration of this motherboard?
A: This is a UMA-only configuration with Intel CPU 17W/GT2 graphics.
  • Acer Aspire V5-531 V5-571=Wistron Petra UMA.pdf
