Schematic acer e1-471g quanta zqta zqsa usb rev-c 1130 rev-1a schematic
acer e1-471g quanta zqta zqsa usb rev-c 1130 rev-1a 1
BrandQuanta Computer Inc.
ProjectUSB Board
Document NumberZQS
RevisionA
DateWednesday, November 30, 2011
This Quanta Computer Inc. USB Board, documented under project USB Board with document number ZQS revision A, dated November 30, 2011, is a dedicated USB sub-board. The schematic details a USB connector assembly featuring two USB_MB_Turbo connectors (CN1, CN2) and one USB_CONN connector (CN3). The board includes power filtering and decoupling components, with capacitors such as 100U/6.3V_3528 (C2, C5), 1000P/50V_4 (C1, C4), and a 10u/6.3V_6 (C6). ESD protection is provided by EGA-0402 varistors (RV1, RV2, RV3, RV4). The power rail is identified as +5VPCU_USBP0, supplying the USB ports.
Q: What is the document number and revision of this USB board?
A: The document number is ZQS, revision A, dated November 30, 2011.
Q: What connectors are used on this USB board?
A: The board uses two USB_MB_Turbo connectors (CN1, CN2) and one USB_CONN connector (CN3).
Q: What is the power supply rail for the USB ports?
A: The USB ports are powered by the +5VPCU_USBP0 rail.
  • Acer_E1-471G=1=Quanta_ZQTA_ZQSA_USB_Rev-C_1130_Rev-1A.pdf
