Schematic acer husk-petra dis 20120412 rev-2.0 husk nvidia 2 n13p-gl csd schematic
acer husk-petra dis 20120412 rev-2.0 husk nvidia 2 n13p-gl csd 1
BrandWistron Corporation
ModelHusk/Petra-2
Project Code91.4TU01.001
Board NumberA31103
Revision-2
DateThursday, April 19, 2012
CPU PlatformIvy Bridge
PCH / SouthbridgeSandy Bridge PCH: HM70/77 Panther Point
GPU TypeNvidia N13P-GL
Graphics Architecture16 lane/128bit/29x29mm
EC / KBCNPCE885
Audio CodecALC271X
BIOS / SPI FlashSPI Flash ROM 8MB
Charging ICBQ24727
Charger ArchitectureINPUTS DCBATOUT
Power IC(s)RT8223MGQW, ISL95836HRTZ, TPS51218DSCR, RT8207LGQW, RT9025-25ZSP, G978, ISL62882CHRTZ
RAM TypeDDRIII
RAM Architecture1600/1333
RAM Quantity / Slots2
Card Reader ICRTL8411
LAN ICRTL8411
WiFi / WLAN IC802.11a/b/g
Thermal SensorNCT7718W
This Wistron Husk/Petra-2 motherboard, project code 91.4TU01.001 and board number A31103 revision -2, is built around an Ivy Bridge CPU platform paired with a Sandy Bridge PCH HM70/77 Panther Point southbridge. The graphics subsystem features an Nvidia N13P-GL GPU in a 16 lane/128bit/29x29mm configuration. System management is handled by an NPCE885 EC/KBC, while audio is provided by an ALC271X codec. The BIOS is stored on an 8MB SPI flash ROM. Power management includes a BQ24727 charger IC and multiple DC/DC converters such as the ISL95836HRTZ, RT8207LGQW, and ISL62882CHRTZ. Memory architecture supports DDRIII 1600/1333 across two slots. The board integrates an RTL8411 for both LAN and card reader functions, an NCT7718W thermal sensor, and 802.11a/b/g wireless connectivity.
A: The BIOS is stored on an 8MB SPI flash ROM.
A: The EC/KBC controller is an NPCE885.
A: The charging IC is a BQ24727, with the charger architecture using DCBATOUT as the input.
Q: What is the GPU configuration on this board?
A: The GPU is an Nvidia N13P-GL with a 16 lane/128bit/29x29mm architecture.
  • Acer=1=Husk-Petra_DIS_20120412_Rev-2.0_husk_nvidia_2_n13p-gl_CSD.pdf
