acer iconia tablet a200 la-8111p qcj00 rev1.0
The Compal QCJ00 (Picasso-E) motherboard, documented under board number LA-8111P revision 1.0 dated 2011-10-21, is built around the Nvidia Tegra T20 CPU platform. Memory architecture consists of LPDDR2 with a 32-bit bus, configurable as 512MB or 1GB. System management is handled by the KB930 EC/KBC. Audio processing is provided by the Wolfson WM8903 audio codec. Power management is split between the TPS51220 charging IC and the TI TPS658621C PMU. Wireless connectivity is supported by the AW-NH611 WiFi/BT module. Thermal monitoring is performed by the NCT-1008 temperature sensor, and card reader functionality is managed by the FM2018 controller.
A: The EC/KBC is a KB930.
Q: What is the CPU platform for this motherboard?
A: The CPU platform is the Nvidia Tegra T20.
Q: What type of memory does this motherboard use?
A: This motherboard uses LPDDR2 memory with a 32-bit bus, configurable as 512MB or 1GB.
A: The audio codec is a Wolfson WM8903.
| Model | QCJ00 (Picasso-E) |
| Board Number | LA-8111P |
| Date | 2011-10-21 |
| CPU Platform | Nvidia Tegra T20 |
| EC / KBC | KB930 |
| Audio Codec | Wolfson WM8903 |
| RAM Type | LPDDR2 |
| RAM Architecture | 32 bits |
| RAM Quantity / Slots | 512MB / 1GB |
| WiFi / WLAN IC | AW-NH611 |
| Charging IC | TPS51220 |
| Power IC(s) | TI TPS658621C |
| Thermal Sensor | NCT-1008 |
| Card Reader IC | FM2018 |
