acer inventec caltech braswell cs2 schematic5 gerber
This Inventec CS2 BUILD motherboard, designated Oxford 14" / Caltech 11.6" (BSW), is built on the Braswell CPU platform. The embedded controller is an NPCE985LB0DX in a TERMINUS_FE11S_BSOP28BC_28P package. The BIOS SPI flash is a Winbond W25Q64FVSSIG 8MB IC in an SOIC_8P package. Audio is handled by a Realtek ALC233 codec. The charging subsystem uses a TI BQ24725ARGRR charger IC. Power regulation is managed by NCP81201, NB670GQ, NB671LGQ, and RT5041AGQW controllers. Memory is DDR3L in a memory-down configuration. The thermal sensor is a GMT-AT9667. The card reader controller is a GL9755, and the system includes a USB hub IC and HDMI level shifter.
A: The BIOS SPI flash is a Winbond W25Q64FVSSIG in an SOIC_8P package, with a capacity of 8MB.
Q: What EC/KBC chip is used on this motherboard?
A: The embedded controller is an NPCE985LB0DX in a TERMINUS_FE11S_BSOP28BC_28P package.
A: The charger IC is a TI BQ24725ARGRR in a QFN-20 package.
Q: What memory architecture does this motherboard use?
A: The motherboard uses DDR3L memory in a memory-down configuration.
| Brand | Inventec |
| Model | Caltech 11.6" (BSW) |
| Motherboard Manufacturer | Inventec |
| Project Code | Oxford 14" |
| Board Number | CS2 BUILD |
| Date | 21-OCT-2002 |
| CPU Platform | Braswell |
| EC / KBC | NPCE985LB0DX |
| EC/KBC Package | TERMINUS_FE11S_BSOP28BC_28P |
| Audio Codec | REA_ALC233_VB2_CGT |
| BIOS / SPI Flash | w25q64fvssig-soic-8p/"]W25Q64FVSSIG_SOIC_8P[/URL] |
| BIOS Flash Exact Model | W25Q64FVSSIG |
| BIOS Flash Manufacturer | Winbond |
| BIOS Flash Capacity | 8MB |
| BIOS Flash Package | SOIC_8P |
| Charging IC | TI_BQ24725ARGRR_QFN_20 |
| Charger Architecture | BQ24725N |
| Power IC(s) | NCP81201, NCP81201B, NB670GQ, NB671LGQ, RT5041AGQW |
| RAM Type | DDR3L |
| RAM Architecture | Memory Down |
| RAM Quantity / Slots | 2S1P |
| Thermal Sensor | GMT-AT9667 |
| Card Reader IC | GL9755 |
| USB Hub IC | USB HUB |
| WiFi / WLAN IC | MINICARD WLAN |
| HDMI Level Shifter | LEVEL SHIFT |
CS2 BUILD
Braswell
NPCE985LB0DX
REA_ALC233_VB2_CGT
BIOS / EC Flash
W25Q64FVSSIG
BIOS / EC Flash
BQ24725ARGRR_QFN_20
NB670GQ
NB671LGQ
NCP81201
NCP81201B
RT5041AGQW
DDR3L
GMT-AT9667
GL9755
CS2 BUILD
Braswell
NPCE985LB0DX
REA_ALC233_VB2_CGT
BIOS / EC Flash
W25Q64FVSSIG
BIOS / EC Flash
BQ24725ARGRR_QFN_20
NB670GQ
NB671LGQ
NCP81201
NCP81201B
RT5041AGQW
DDR3L
GMT-AT9667
GL9755
