Schematic Acer SP714-61N Compal LA-K501P Schematic
BrandCompal
ModelGH4PX
Project CodeLA-K501P
Board NumberLA-K501P
Revision0.12
Date2020.03.20
CPU PlatformQualcomm SC8180X
EC / KBCENE KB9022
Audio CodecWCD9341
Audio AmplifierWSA8815 X2
Charging ICSMB2351
Charger Architecture2S Charger
Power IC(s)PMC8180C, PMC8180 x2, PMK8002, PMC1000H x2
RAM TypeLPDDR4
RAM Architecture64 BIT x2 pcs 16GB
RAM Quantity / Slots2
WiFi / WLAN ICWCN3998
USB Hub ICFSUSB42UMX
Graphics ArchitectureQualcomm Adreno (integrated in SC8180X)
The Compal GH4PX (LA-K501P) is a 13.3-inch convertible motherboard powered by the Qualcomm SC8180X octa-core 7nm FinFET SoC. The platform integrates LPDDR4 memory configured as 64-bit dual-channel with two 16GB packages. System power management is handled by a suite of Qualcomm PMICs including PMC8180C, dual PMC8180, PMK8002, and dual PMC1000H. Charging is managed by the SMB2351 2S charger IC. The embedded controller is an ENE KB9022. Audio processing is provided by the WCD9341 codec paired with dual WSA8815 amplifiers. Wireless connectivity uses the WCN3998 module. The board includes dual FSUSB42UMX USB-C multiplexers for USB3.1 Gen2 and DP Alt Mode support.
Q: What EC/KBC is used on the GH4PX?
A: The embedded controller is an ENE KB9022.
Q: What is the charging architecture of this motherboard?
A: The charging architecture uses an SMB2351 2S charger IC.
Q: What memory configuration does the GH4PX use?
A: The board uses LPDDR4 memory in a 64-bit dual-channel configuration with two 16GB packages.
Q: What audio components are present on this board?
A: The audio subsystem consists of a WCD9341 codec and dual WSA8815 amplifiers.
Reuse permitted only with source attribution.
  • Acer SP714-61N Compal LA-K501P Schematic.pdf
