acer switch 10 fendi mb sch byt r20 20140331
The PEGATRON FENDI Zara2 project is an Intel BayTrail-T platform motherboard designed by engineer Hank Wang, revision 1.0, dated 31, 2014. The system utilizes an ITE IT8566E EC/KBC with debug capability, paired with an 8 MB SPI ROM for BIOS storage. Memory architecture consists of two-channel LPDDR3 at 2GB 1066MHz. Power management is handled by a ROHM PMIC, with charging controlled by a TI BQ24192 USB charger IC. Audio is managed by a Realtek ALC5642 codec, while wireless connectivity is provided by a Foxconn T77H462 module. The board features a TI BQ27520 gas gauge, a TPS61176 LED driver, and an NXP NX3DV221 card reader IC. Display interfacing includes a PS8622 HDMI level shifter. Sensor integration includes an Invensense MPU6500 G-sensor and gyro, an AKM AK9911 eCompass, and a Capella CM32181 ALS. The camera module is an OV2720, and the vibrator controller is a FENDI BD2610GW.
Q: What is the EC/KBC model used on this motherboard?
A: The EC/KBC is an ITE IT8566E, with an EC_debug programming interface.
A: The BIOS is stored on an 8 MB SPI ROM.
Q: What is the charging architecture?
A: The charging architecture uses a TI BQ24192 USB charger IC.
A: The memory is two-channel LPDDR3 at 2GB
| Brand | PEGATRON |
| Project Name | FENDI |
| Project Code | Zara2 |
| Date | 31, 2014 |
| Engineer | HANK WANG |
| CPU Platform | Intel BayTrail-T |
| EC / KBC | ITE IT8566E |
| EC/KBC Programmable | EC_debug |
| Audio Codec | Realtek ALC5642 |
| BIOS / SPI Flash | SPI ROM 8 MB |
| Charging IC | TI BQ24192 |
| Charger Architecture | USB Charger |
| Power IC(s) | ROHM PMIC |
| RAM Type | LPDDR3 |
| RAM Architecture | Two Channel LPDDR3 2GB 1066MHz |
| Card Reader IC | NXP NX3DV221 |
| LAN IC | Realtek ALC5642 |
| WiFi / WLAN IC | Foxconn T77H462 |
| HDMI Level Shifter | PS8622 |
| Gas Gauge IC | TI BQ27520 |
| LED Driver | TPS61176 |
| Touch Screen Controller | FPC_CON_12P |
| Camera Module | OV2720 |
| G-Sensor + Gyro | Invensense MPU6500 |
| eCompass | AKM AK9911 |
| ALS | Capella CM32181 |
| Vibrator Controller | FENDI BD2610GW |
| Battery Gauge | BQ27520 |
| USB Hub IC | N/A |
| Thermal Sensor | N/A |
