Schematic acer travelmate 4240 4420 4520 wistron orta rev-sa schematic
acer travelmate 4240 4420 4520 wistron orta rev-sa 1
BrandWistron
ModelOrta
Project Code91.4U101.001
Board Number48.4U101.0SA
Revision06245-SA
DateTuesday, December 12, 2006
Document NumberSA
CPU PlatformAMD K8 Rev. GS1g1 Socket PA
PCH / SouthbridgeSB600
GPU TypeATI RS690M
Graphics ArchitectureATI
EC / KBCWPC8768L
EC/KBC ManufacturerWinbond
Audio CodecALC268
BIOS / SPI FlashW25X80-V
BIOS Flash ManufacturerWinbond
BIOS Flash Capacity1MB (8Mbit)
Charging ICO2OZ711
RAM TypeDDR2 SODIMM
RAM ArchitectureDDR II 533/667/800
RAM Quantity / Slots2
LAN ICBCM5787M
Card Reader ICG1432Q
USB Hub ICCP2211F
WiFi / WLAN ICG1410Q
The Wistron Orta motherboard, project code 91.4U101.001 with board number 48.4U101.0SA revision 06245-SA, is an AMD-based platform designed around the K8 Rev. GS1g1 Socket PA CPU architecture. The platform integrates an ATI RS690M graphics solution paired with an SB600 southbridge. System memory is provided by two DDR2 SODIMM slots supporting DDR II 533/667/800 modules. The embedded controller is a Winbond WPC8768L, while the BIOS SPI flash is a Winbond W25X80-V. Audio is handled by an ALC268 codec, and networking is provided by a BCM5787M LAN controller. The charging circuit utilizes an O2OZ711 IC. Additional connectivity includes a G1432Q card reader, a CP2211F USB hub, and a G1410Q wireless module.
A: The BIOS SPI flash is a Winbond W25X80-V.
A: The embedded controller is a Winbond WPC8768L.
A: The charging IC is an O2OZ711.
Q: What is the LAN IC on this motherboard?
A: The LAN IC is a BCM5787M.
  • Acer_TravelMate_4240_4420_4520=1=Wistron_ORTA_Rev-SA.pdf
