Schematic acer travelmate 4240 4420 4520 wistron orta revsa schematic
acer travelmate 4240 4420 4520 wistron orta_revsa schematic
acer travelmate 4240 4420 4520=1=wistron orta_revsa.pdf
BrandWistron
ModelOrta
Project Code91.4U101.001
Board Number48.4U101.0SA
Revision06245-SA
DateTuesday, December 12, 2006
CPU PlatformK8 Rev.G
CPU SocketSocket 1
PCH / SouthbridgeSB600
GPU TypeATI RS690M
EC / KBCWPC8768L
EC/KBC ManufacturerWinbond
Audio CodecALC268
BIOS / SPI FlashW25X80-V
BIOS Flash ManufacturerWinbond
Charging ICO2OZ711
RAM TypeDDR2 SODIMM
RAM Quantity / Slots2
LAN ICBCM5787M
Card Reader ICG1432
USB Hub ICCP2211F
WiFi / WLAN ICG1410Q
CLK GEN IC9LPRS502 (RTM875T-605)
Modem ICG792
Cardbus ControllerP2231N
Fingerprint ControllerFinger print
Charger ArchitectureSAD+BAT+Battery Charger
Memory ArchitectureDDR II 533/667/800
Graphics ArchitectureATI RS690M
Audio Codec ArchitectureAzalia
LAN Architecture10/100/1000
Wireless Architecture802.11a/b/g/n
PCB Layer StackupL1: Signal 1, L2: VCC, L3: Inner Signal 2, L4: Inner Signal 3, L5: GND, L6: Signal 4
The Wistron Orta motherboard, project code 91.4U101.001 with board number 48.4U101.0SA revision 06245-SA, is built around an AMD K8 Rev.G socket 1 CPU platform paired with an ATI RS690M integrated GPU and an SB600 southbridge. The system memory architecture supports DDR2 SODIMM modules at 533/667/800 MHz across two slots. The embedded controller is a Winbond WPC8768L, and the BIOS SPI flash is a Winbond W25X80-V. Audio is handled by a Realtek ALC268 Azalia codec, while networking is provided by a Broadcom BCM5787M 10/100/1000 LAN controller. Wireless connectivity supports 802.11a/b/g/n via a G1410Q Mini Card interface. The charging architecture is based on an O2OZ711 charger IC with SAD+BAT+Battery Charger topology. The PCB utilizes a 6-layer stackup with dedicated signal, power, and ground planes.
A: The BIOS SPI flash is a Winbond W25X80-V.
A: The
  • Acer TravelMate 4240 4420 4520=1=Wistron Orta_RevSA.zip
