acer zsjvv ls-a401p r02 audio 0222 r0.1
This Compal LS-A401P audio board, revision 0.1, dated 2013/02/22, is identified by board number DA4001Q4000 and PCB name LS-A401P REV0 AUDIO/B. The audio subsystem is built around an IQS1280000EBTSR audio codec in a TSOT23 6-pin package. The board includes a PROCO_879B-N004-00A0 headphone jack connector and an ACES_51522-00801-001 connector. Passive components include 0402-size resistors and capacitors, along with TVNST52302AB0 EMC protection diodes. The board is manufactured by Compal Electronics, Inc. and classified as Compal Secret Data.
Q: What is the audio codec used on this board?
A: The audio codec is an IQS1280000EBTSR in a TSOT23 6-pin package.
Q: What is the PCB name and revision of this audio board?
A: The PCB name is LS-A401P REV0 AUDIO/B, revision 0.1.
Q: What is the board number for this Compal audio board?
A: The board number is DA4001Q4000.
| Brand | COMPAL |
| Model | LS-A401P |
| Board Number | DA4001Q4000 |
| Revision | 0.1 |
| Date | 2013/02/22 |
| PCB Name | LS-A401P REV0 AUDIO/B |
| Audio Codec | IQS1280000EBTSR TSOT23 6P |
