Schematic apple a1418 imac 21.5 late 2013 apple j16 mlb ig 051-0164 820-3588 schematic
BrandApple Inc.
ModelJ16 MLB_IG
Motherboard ManufacturerApple Inc.
Board NumberJ16 MLB_IG
Revision12.4.0
Date2013-03-22
CPU PlatformJ16
MLB IdentifierJ16 MLB_IG
Drawing Number051-01642
051- Drawing Number051-01642
Schematic Number051-01642
This Apple Inc. motherboard schematic, designated J16 MLB_IG, is identified by drawing number 051-01642 and dated 2013-03-22 with revision 12.4.0. The board is built around the J16 CPU platform. The schematic document spans 86 sheets and includes detailed sections for CPU, PCH, DDR3 memory, Thunderbolt host and power support, audio codec and amplifiers, LCD backlight driver, and various power regulation and aliasing pages. The document also contains constraint pages for DDR3, CPU, PCH, PCIe, DMI, SATA, USB, Ethernet, SD, SMBus, sensors, and voltage regulators.
Q: What is the drawing number for this Apple motherboard?
A: The drawing number is 051-01642.
Q: What is the MLB identifier for this board?
A: The MLB identifier is J16 MLB_IG.
Q: What is the revision of this schematic?
A: The schematic revision is 12.4.0.
  • Apple A1418 iMac 21.5 Late 2013=Apple J16 MLB IG 051-0164 820-3588.pdf
