apple a1466 bj43 mlb_051-9800 820-3437 apple a1466 bj43 mlb_051-9800 820-3437 schematic
apple a1466=bj43 mlb_051-9800 820-3437.pdf
This Apple J43 MLB DVT schematic, revision 6.5.0 dated April 9, 2013, documents a Haswell-based platform with LPDDR3 memory configured across four banks in dual-channel architecture (Channel A and B, each split into 0-31 and 32-63 bit ranges). The board integrates a GL3219 SD controller for the SD card reader interface. The schematic includes detailed power delivery sections such as CPU VR12.5/12.6 VCC regulation, PBus supply and battery charger, LPDDR3 supply, and LCD/KBD backlight driver. Connectivity is supported by Thunderbolt host controllers, a wireless connector, and an external USB3 connector. The document also specifies SMC (System Management Controller) support and project-specific constraints for memory, PCH, CPU, Thunderbolt, and camera subsystems.
Q: What is the board number and revision of this schematic?
A: The board is identified as J43 MLB SCHEMATIC DVT, revision 6.5.0, dated April 9, 2013.
Q: What type of memory is used on this motherboard?
A: The board uses LPDDR3 memory in a dual-channel architecture with four banks: Channel A (0-31 and 32-63) and Channel B (0-31 and 32-63).
Q: What SD card controller is used on this motherboard?
A: The SD card controller is a GL3219, located on page 34 of the schematic.
Q: What CPU platform is documented in this schematic?
A: The schematic documents a Haswell CPU platform, as indicated by the CPU/PCH merged XDP and VR12.5/12.6 VCC power stage references.
| Brand | Apple Inc. |
| Motherboard Manufacturer | Apple Inc. |
| Board Number | J43 MLB SCHEMATIC DVT |
| Revision | REV 6.5.0 |
| Date | 04/09/13 |
| CPU Platform | Haswell |
| MLB Identifier | J43 MLB |
| Drawing Number | 456-00206 |
| RAM Type | LPDDR3 |
| RAM Quantity / Slots | 4 Banks (Channel A 0-31, Channel A 32-63, Channel B 0-31, Channel B 32-63) |
| Card Reader IC | GL3219 |
| SD Controller | GL3219 |
