Schematic apple imac 27 a1312 k23 051-7863-a schematic
apple imac 27 a1312 k23_051-7863-a schematic
apple imac 27 a1312=1=k23_051-7863-a.pdf
BrandApple Inc.
Motherboard ManufacturerApple Inc.
Project CodeK22
Board NumberK22
RevisionA
Date2009-08-20
Drawing Number051-7863
Document Number07774489
CPU PlatformK22
MLB IdentifierK22
Schematic Number051-7863
This Apple Inc. motherboard, identified by project code K22 and MLB identifier K22, is documented under drawing number 051-7863 and document number 07774489. The schematic was released on 2009-08-20 at revision A. The board is based on the K22 CPU platform and includes subsystems such as SPI ROM, audio codec/regulator, Ethernet PHY (RTL8211CL), FireWire LLC/PHY (XIO2213B), DDR3 SO-DIMM memory support, and SMC controller. The schematic covers power sequencing, voltage regulators including PPVCORE_S0_CPU, 5V_S3 regulator, MCP core regulator, 1.5V DDR supply, and FSB VTT/3.3V S5 supplies. Display interfaces include internal and external DP connectors with BiDiVi mux support. The board also features MXM PCIe, DP and power sections, and constraints for CPU/FSB, memory, MCP, Ethernet, FireWire, SMC, and graphics.
Q: What is the board number and revision of this Apple motherboard?
A: The board number is K22, revision A, with drawing number 051-7863 and document number 07774489.
A: The motherboard is based on the K22 CPU platform.
Q: What Ethernet PHY is used on this motherboard?
A: The Ethernet PHY is RTL8211CL.
Q: What FireWire controller is used on this motherboard?
A: The FireWire LLC/PHY is XIO2213B.
A: The motherboard supports DDR3 SO-DIMM memory modules.
  • Apple iMac 27 A1312=1=K23_051-7863-A.zip
