apple ipad 2 chopin mlb pvt k94 051-8962 schematic
ipad 2.pdf
ipad2layout.pdf
This Apple Inc. motherboard, designated as CHOPIN MLB with drawing number 051-8962 revision A.0.0, is dated 2011-01-10. The platform is built around an ARM A5 CPU. The system block diagram indicates a dual-core ARM Cortex-A9 with SMP, an SGX543-MP dual-core IMG GPU, and an Alison PMU. Memory architecture includes LPDDR2 at 400 MHz / 800 MB/s configured as 2x32-bit. The board integrates an MLC NAND flash controller, an audio codec (L63), and supports interfaces including LVDS, DisplayPort, MIPI, USB 2.0, HSIC, UART, I2C, SPI, and SDIO. Connectivity options include WiFi/BT via X23 and Cellular/GPS via X24.
Q: What is the board number and revision for this Apple motherboard?
A: The board is identified as CHOPIN MLB, drawing number 051-8962, revision A.0.0.
Q: What CPU platform is used on this motherboard?
A: The CPU platform is an ARM A5 CPU, with a dual-core ARM Cortex-A9 with SMP.
Q: What is the memory architecture on this board?
A: The memory is LPDDR2 at 400 MHz / 800 MB/s configured as 2x32-bit.
This motherboard is identified by the board number 820-3069-A, as indicated on the schematic layout. The document provides a component placement diagram for the left and right sections of the main logic board (MLB). The schematic includes numerous passive components, connectors, and integrated circuits, but specific models for the CPU, PCH, EC/KBC, BIOS flash, or other programmable devices are not explicitly listed in the provided text.
Q: What is the board number for this motherboard?
A: The board number is 820-3069-A.
ipad 2.pdf
ipad2layout.pdf
| Brand | Apple Inc. |
| Motherboard Manufacturer | Apple Inc. |
| Project Code | CHOPIN MLB |
| Board Number | CHOPIN MLB |
| Revision | A.0.0 |
| Date | 2011-01-10 |
| CPU Platform | ARM A5 CPU |
| MLB Identifier | CHOPIN MLB |
| Drawing Number | 051-8962 |
| 051- Drawing Number | 051-8962 |
| Schematic Number | 051-8962 |
| Document Number | 051-8962 |
| Board Number | 820-3069-A |
