apple ipad mini 2 retina x200
This Apple motherboard schematic, designated MLB-C1,X200, corresponds to PCB number 820-4124 and drawing number 051-0886. The document is at revision A.0.0 with a production release date of 2014-01-13. The schematic includes block diagrams for the system, SOC, power management (PMU ANYA), audio (L81 CODEC and CS35L19A amps), NAND storage, cellular RF subsystems (baseband, transceiver, PA, antenna feeds), WiFi/BT module, sensors (accelerometer, compass, gyro, proximity, Oscar), cameras, and IO interfaces including Tristar, EDP, and MIPI. The board integrates an SOC with SRAM, CPU, and GPU power domains, and supports cellular, WiFi, and GPS antenna configurations.
Q: What are the board and schematic identifiers for this Apple motherboard?
A: The PCB number is 820-4124, the schematic number is 051-0886, and the MLB identifier is MLB-C1,X200.
Q: What is the revision and release date of this schematic?
A: The schematic is at revision A.0.0 and was released for production on 2014-01-13.
Q: What audio components are documented in this schematic?
A: The schematic includes the L81 CODEC and CS35L19A amplifiers.
| Brand | Apple Inc. |
| Motherboard Manufacturer | Apple Inc. |
| Board Number | 820-4124 |
| Revision | A.0.0 |
| Date | 2014-01-13 |
| MLB Identifier | MLB-C1,X200 |
| Drawing Number | 051-0886 |
| 820- Board Number | 820-4124 |
| 051- Drawing Number | 051-0886 |
| PCB Number | 820-4124 |
| Schematic Number | 051-0886 |
