apple m9 sully pw2-pi2 051-7023 rev 06.pdf
This Apple Computer Inc. schematic, revision (6.0.0) dated 3/3/2006, documents the M9 MLB project with board number M1_MLB. The platform is identified as the Napa Platform, featuring an Intel CPU with an ATI M56 GPU and GDDR3 frame buffer memory. The design includes DDR2 SO-DIMM connectors, FireWire PHY and Link (TSB83AA22), an Ethernet controller, and a Yukon Power Control section. The schematic covers IMVP6 CPU VCore regulation, multiple power supply rails, and an SPI interface. The drawing number is 86104M1_MLB.
Q: What is the board number and project code for this Apple motherboard?
A: The board number is M1_MLB and the project code is M9 MLB.
A: This motherboard uses the Napa Platform.
Q: What GPU is used on this motherboard?
A: The motherboard uses an ATI M56 GPU with GDDR3 frame buffer memory.
| Brand | Apple Computer Inc. |
| Project Code | M9 MLB |
| Board Number | M1_MLB |
| Revision | (6.0.0) |
| Date | 3/3/2006 |
| CPU Platform | Napa Platform |
| MLB Identifier | M1_MLB |
| Drawing Number | 86104M1_MLB |
| Schematic Number | 86104M1_MLB |
