apple macbook pro15.4_a1211 820-2054_mlb_m59 schematic
apple macbook pro15.4_a1211=1=820-2054_mlb_m59.pdf
This Apple Computer Inc. motherboard, identified as the M59 MLB with board number 820-2054, is based on the Intel Napa CPU platform. The schematic, drawing number 051-7150, was released under revision A.0.0 on September 19, 2006. The board features an ATI M56 PCI-E GPU with GDDR3 frame buffer memory, supported by an IMVP6 CPU VCore regulator. The system architecture includes DDR2 SO-DIMM memory slots, a Southbridge (SB), and a Northbridge (NB) with DDR2 interfaces. The schematic documents the SPI BOOTROM, SMC (System Management Controller), FireWire ports, and various power supply rails including 5V, 1.5V, 1.8V, 2.5V, 1.2V, 3.3V, and 1.05V.
Q: What is the board number for this Apple motherboard?
A: The board number is 820-2054.
Q: What is the drawing number for this schematic?
A: The drawing number is 051-7150.
A: This motherboard uses the Intel Napa CPU platform.
Q: What GPU is documented in this schematic?
A: The schematic documents the ATI M56 PCI-E GPU with GDDR3 frame buffer memory.
| Brand | Apple Computer Inc. |
| Motherboard Manufacturer | Apple Computer Inc. |
| Project Code | M59 |
| Board Number | 820-2054 |
| Revision | A.0.0 |
| Date | 09/19/2006 |
| CPU Platform | Napa |
| MLB Identifier | M59_MLB |
| Drawing Number | 051-7150 |
| 820- Board Number | 820-2054 |
| 051- Drawing Number | 051-7150 |
| Schematic Number | 051-71501 |
