apple n71 mlb pvt ok2fab 820-5507 051-1902 1
This Apple N71 MLB PVT motherboard, identified by drawing number 051-1902 and board number 820-5507, is an Apple Inc. production design dated July 21, 2015, at revision A.0.0. The platform is centered around an SOC architecture, with system power managed by a PMU and a dedicated charger section. The board integrates cellular baseband and transceiver subsystems, a WLAN/BT module, and audio processing via a Caltra codec. Display and camera interfaces are supported through Kepler and forehead flex B2B connectors, respectively. The design includes a Tristar 2 I/O controller and a Stockholm SIM interface. Power delivery is distributed across multiple PMU and cellular PMU sections, with battery connection and motion sensor support. The board also features a debug connector and test points for diagnostic access.
Q: What is the board number and drawing number for this Apple motherboard?
A: The board number is 820-5507, and the drawing number is 051-1902.
Q: What is the revision and date of this schematic?
A: The schematic is revision A.0.0, dated July 21, 2015.
Q: What is the CPU platform architecture?
A: The platform is based on an SOC (System on Chip) architecture.
A: The audio subsystem uses a Caltra codec.
| Brand | Apple Inc. |
| Model | N71 MLB - PVT |
| Motherboard Manufacturer | Apple Inc. |
| Board Number | 820-5507 |
| Revision | A.0.0 |
| Date | 2015-07-21 |
| CPU Platform | SOC |
| Drawing Number | 051-1902 |
| 820- Board Number | 820-5507 |
| 051- Drawing Number | 051-1902 |
| Schematic Number | 051-1902 |
| Document Number | 051-1902 |
