Technical Support Asus A560U power supply question
user10002
I have an Asus A560U that wont turn on , the main voltages are ok , 19v , 3.3v , 5v
Board X560UD REV 2.0
My question is the following, I don't have the original transformer, that is, I don't know if the middle pin has to carry some type of signal or mass or voltage, can you help?
Regards
Usually, in Dell, HP, and Apple laptops, the middle wire is connected to EC through the One Wire protocol, and I did not see it in Asus laptops.
According to the board, only voltage and ground are connected and no data is exchanged.
user10002
yes you are right , thank you for the help
Regards
