ASUS FX506 Quanta NJJ DANJJMB1AA0 Schematic
The ASUS FX506H motherboard, designed by Quanta Computer Inc. under project code NJJ162 revision 1A, is built around an Intel Tiger Lake-H 8+2 CPU platform paired with a TGL PCH. Graphics are handled by an NVIDIA GN20-P0/P1 N18P-G61-A dGPU with GDDR6x VRAM configured as 4 pcs 2CHx256Mx16. The system memory architecture supports DDR4 3200MHz across two SODIMM slots, each supporting up to 16GB, organized as Channel A and Channel B. The embedded controller is an ITE IT5570VG-128/DX, and the audio codec is an ALC3251-CG. The BIOS is stored on a SPI ROM. Charging is managed by a TI PD TPS65992 controller. Networking includes an RTL8111K or RTL8125 LAN IC and a CNVi/PCIe M.2 2230 WLAN/BT module. HDMI connectivity is supported via a PS8409A re-driver.
Q: What is the EC/KBC model used on this motherboard?
A: The embedded controller is an ITE IT5570VG-128/DX.
Q: What is the dGPU configuration on this motherboard?
A: The dGPU is an NVIDIA GN20-P0/P1 N18P-G61-A with GDDR6x VRAM, 4 pcs 2CHx256Mx16.
A: The motherboard supports DDR4 3200MHz memory across two SODIMM slots, each supporting up to 16GB, configured as Channel A and Channel B.
A: The charging IC is a TI PD TPS65992.
Q: What LAN and WLAN ICs are used?
A: The LAN IC is an RTL8111K or RTL8125, and the WLAN/BT module uses a CNVi & PCIe M.2 2230 interface.
| Brand | ASUS |
| Model | FX506H |
| Motherboard Manufacturer | Quanta Computer Inc. |
| Project Code | NJJ162 |
| Revision | 1A |
| Date | Tuesday, June 08, 2021 |
| CPU Platform | Tiger Lake - H 8+2 |
| GPU Type | NVIDIA GN20-P0/P1 N18P-G61-A |
| Graphics Architecture | VRAM GDDR6x 4 pcs 2CHx256Mx16 |
| EC / KBC | ITE IT5570VG-128/DX |
| Audio Codec | ALC3251-CG |
| Charging IC | TI PD TPS65992 |
| RAM Type | DDR4 3200MHz |
| RAM Architecture | Channel A / Channel B |
| RAM Quantity / Slots | SODIMM1 Max. 16GB / SODIMM2 Max. 16GB |
| LAN IC | RTL8111K / RTL8125 |
| WiFi / WLAN IC | WLAN / BT ( CNVi & PCIe ) M.2 2230 |
| HDMI Level Shifter | PS8409A |
| PCH / Southbridge | TGL PCH |
| dGPU Chip Number | GN20-P0/P1 N18P-G61-A |
NJJ162
Tiger Lake - H 8+2
IT5570VG-128/DX
ALC3251-CG
PD TPS65992
DDR4 3200MHZ
RTL8111K / RTL8125
PS8409A
TGL PCH
NJJ162
Tiger Lake - H 8+2
IT5570VG-128/DX
ALC3251-CG
PD TPS65992
DDR4 3200MHZ
RTL8111K / RTL8125
PS8409A
TGL PCH
