Asus PRIME Z790M-PLUS D5 Schematic
The ASUS PRIME Z790M-PLUS D5 motherboard, revision R1.00 dated October 20, 2022, is built on the Intel RPL PCH platform supporting LGA-1700 socket Intel processors. The board features dual-channel DDR5 memory architecture and integrates a Realtek ALC897 audio codec and an Intel I219V LAN controller. System monitoring and control are handled by an NCT6798D Super I/O. The BIOS is stored on a SPI flash device. Display connectivity includes an ASM1442K HDMI 2.1 level shifter. USB expansion is supported by a GL850 USB 2.0 hub, GL9905 and PI3EQX1002E USB redrivers, and an ASM1543 USB-C controller. The voltage regulation subsystem employs multiple controllers including ISL99390, ISL69269, APW8723AQBI-TRG, UP8815PDA, APL5337KAI-TRG, NCP302045, RT7276GQW, RT6541A, APW8743, and RT6543AGQW for core, GT, SA, IO, VCCST, VCCSTG, VTTDDR, VPPDDR, and auxiliary rails.
Q: What audio codec is used on the PRIME Z790M-PLUS D5?
A: The motherboard uses a Realtek ALC897 audio codec.
Q: What LAN controller is integrated on this board?
A: The board features an Intel I219V LAN controller.
Q: What type of memory does this motherboard support?
A: The PRIME Z790M-PLUS D5 supports DDR5 memory in a dual-channel (Channel A / Channel B) architecture.
Q: What Super I/O chip is used for system monitoring?
A: The board uses an Nuvoton NCT6798D Super I/O.
Q: What HDMI level shifter is present on this board?
A: The board includes an ASM1442K HDMI
| Brand | ASUSTek COMPUTER INC. |
| Model | PRIME Z790M-PLUS D5 |
| Project Name | SKYLAKE CHIPSET DEMO |
| Revision | R1.00 |
| Date | Thursday, October 20, 2022 |
| CPU Platform | Intel Processor (LGA-1700 Pin Socket) |
| PCH / Southbridge | INTEL RPL |
| Audio Codec | Realtek ALC897 |
| LAN IC | Intel I219V |
| Super I/O | NCT6798D |
| BIOS / SPI Flash | SPI FLASH |
| HDMI Level Shifter | ASM1442K |
| USB Hub IC | GL850 |
| USB Redriver | GL9905 |
| USB Redriver | PI3EQX1002E |
| USB-C Controller | ASM1543 |
| RAM Type | DDR5 |
| RAM Architecture | Channel A / Channel B |
| VR Controller | ISL99390 |
| VR Controller | ISL69269 |
| VR Controller | APW8723AQBI-TRG |
| VR Controller | UP8815PDA |
| VR Controller | APL5337KAI-TRG |
| VR Controller | NCP302045 |
| VR Controller | RT7276GQW |
| VR Controller | RT6541A |
| VR Controller | APW8743 |
| VR Controller | RT6543AGQW |
