ASUS X512DK X512DA X712DK X712DA Schematic
This motherboard, identified as X512DA/DK and X712DA/DK (Project NB-SZ-RD3, Revision R0.1), is built on an AMD APU platform with an FP5 socket. The discrete graphics solution is an AMD R535 GPU. System control is managed by an IT8985 EC/KBC, which also integrates LAN functionality. Audio is handled by a CX8050 codec. Memory architecture consists of DDR4, with one channel implemented as memory down and the other via a SO-DIMM slot. The board incorporates an AU6465RB63 card reader controller and supports WLAN connectivity.
A: The motherboard uses an IT8985 EC/KBC.
A: The motherboard uses an AMD APU on an FP5 socket.
A: The board supports DDR4 memory with a Channel A memory down configuration and a Channel B SO-DIMM slot.
A: The discrete GPU is an AMD R535.
Reuse permitted only with source attribution.
| Project Name | NB-SZ-RD3 |
| Board Number | X512DA/DK, X712DA/DK |
| Revision | R0.1 |
| Date | Tuesday, February 19, 2019 |
| CPU Platform | AMD APU |
| CPU Socket | FP5 |
| GPU Type | Discrete GPU AMD R535 |
| EC / KBC | IT8985 |
| Audio Codec | CX8050 |
| RAM Type | DDR4 |
| RAM Architecture | DDR4 Channel A (Memory Down), DDR4 Channel B (SO-DIMM) |
| Card Reader IC | AU6465RB63 |
| LAN IC | IT8985 |
| WiFi / WLAN IC | WLAN |
