Technical Support ASUS X555LD REV3.3 NO SCREEN ON LCD HDMI IS OK
Ipart
Hi i have the same problem is two motherboards. It working and show screen only on HDMI but not on LCD screen. I replace LCD screen, LCD cable and U4501.
I checked voltage on LCD connector on motherboard:
PANEL_VCC is 3.3V
+3VS is 3.3V
L_BRIGHTNESS_R is 3.3V
BL_EN is 2,88V
AC_BAT_SYS 19V
Is it ok? Any ideas?
PANEL_VCC is 3.3V
+3VS is 3.3V
BL_EN is 2,88V
AC_BAT_SYS 19V
do you reprogram bios ?
Ipart
Yes but from dump from other motherboard. You think it will be bios? Because one motherboard before bios didnt show screen on HDMI too. After reprogram bios it shows only on HDMI. Could You help me find correct BIOS?
