dr-bios.com
SIR, I TRIED THAT FILE PREVIOUSLY AND IT DOESN'T WORK. IT WORKS WITH MY BACKUP THE PROBLEM IS THAT SOMETIMES IT DOESN'T TURN ON![]()
Bios - Asus ZenBook 14 UX433FN Bios | BIOS Fix for Black Screen / No Display
Download BIOS repair file for Asus ZenBook 14 UX433FN Bios. Useful for black screen, no display and motherboard-level troubleshooting.dr-bios.com
El nuevo archivo nunca se enciende. La copia de seguridad se enciende pero a veces no.El nuevo archivo tampoco se activa a veces.
El problema no está relacionado con la BIOS.
comprobar el hardware.
Cuando presionas el botón de encendido con el respaldo se enciende con un consumo de energía de 1.4A pero cuando no enciende hay un cambio de estado en el consumo a 0.4A.¿Cuántas veces probaste el nuevo archivo?
When you press the power button with the backup it turns on with a power supply consumption of 1.4A but when it does not turn on there is a state change in consumption to 0.4A.engliah please
we don't understand spanish or french
This is file request section. If can simply ask your technical questions from this link:When you press the power button with the backup it turns on with a power supply consumption of 1.4A but when it does not turn on there is a state change in consumption to 0.4A.
With the new file there is no change in consumption status when pressing the power button, remaining at 0.048A at all times.
Thanks youThis is file request section. If can simply ask your technical questions from this link:
Technical Support
Golden premium members can access technical support and discuss their repairing problems and issues with them and get help.dr-bios.com
user33296 , Vahab Hemmati , Salimeh Bolboli , Jaca0815 , ByrnetCom , user51023 , user31562 , user61559
