File Request Bios EC DA0G7AMB6D0 REV D
afonso
tafonso
Hi can someone help with this bios file EC ITE 8987E
MODEL: 14-CE0004NP
MB MODEL: G7A-2G DA0G7AMB6D0 REV D
Thanks,
afonso
tafonso
hi thanks it s now working but no image and caps lock blinks 3 long and 2 short i try replace memory ram but not sucess. can send a bios eeprom file? ?
afonso
tafonso
THANKS i will check again and tell you if i find the problem.
Thanks for fast reply
afonso
tafonso
Hi friend problem solved, memory ram with problems, after resold the pin on memory slot its started work.
Thanks. :)
laup
Member
i have the same issue im glad i saw this, i previously had same unit with nearly the same issue which i resolved doing above method, i was thinking bios this time
will inspect ram holder more closely
