File Request Bios EC DA0G7AMB6D0 REV D
afonso
tafonso
Hi can someone help with this bios file EC ITE 8987E
MODEL: 14-CE0004NP
MB MODEL: G7A-2G DA0G7AMB6D0 REV D
Thanks,
afonso
tafonso
hi thanks it s now working but no image and caps lock blinks 3 long and 2 short i try replace memory ram but not sucess. can send a bios eeprom file? ?
i think that problem is not related to bios or eeprom
afonso
tafonso
THANKS i will check again and tell you if i find the problem.
Thanks for fast reply
you are welcome
afonso
tafonso
Hi friend problem solved, memory ram with problems, after resold the pin on memory slot its started work.
Thanks. :)
laup
i have the same issue im glad i saw this, i previously had same unit with nearly the same issue which i resolved doing above method, i was thinking bios this time
will inspect ram holder more closely
