Clevo NL40CU NL41CU 6-71-NL4C0-D02 Schematic
The NL40CU / NL41CU motherboard is built on the Comet Lake U62 platform with HDCP2.2 support, documented under board numbers 6-71-NL4C0-D02, 6-71-NL4C1-D02, and 6-7P-NL4C5-002, revision D02, dated August 16, 2019. The system employs an ITE IT5570 EC/KBC in a 128-pin LQFP package, paired with an ALC293 audio codec. Memory architecture consists of two DDR4 SO-DIMM slots. The charging subsystem uses a Smart Battery architecture managed by an MP2979A charger IC. Networking is handled by an RTL8411B LAN and card reader combo IC, with wireless connectivity via CNVI. USB-C and DP multiplexing is managed by ANX7440, ANX7411, and ASM1543 controllers.
A: The motherboard uses an ITE IT5570 EC/KBC in a 128-pin LQFP package.
A: The motherboard supports DDR4 memory via two SO-DIMM slots.
Q: What charging architecture does this motherboard use?
A: The motherboard uses a Smart Battery charging architecture with an MP2979A charger IC.
Q: What are the board numbers for this motherboard?
A: The board numbers are 6-71-NL4C0-D02, 6-71-NL4C1-D02, and 6-7P-NL4C5-002, revision D02.
| Board Number | 6-71-NL4C0-D02 |
| Alternate Board Number | 6-71-NL4C1-D02 |
| Alternate Board Number | 6-7P-NL4C5-002 |
| Revision | D02 |
| Date | Friday, August 16, 2019 |
| CPU Platform | Comet Lake U62 (HDCP2.2) |
| EC / KBC | ITE IT5570 |
| EC/KBC Package | 128 pins LQFP |
| Audio Codec | ALC293 |
| RAM Type | DDR4 |
| LAN IC | RTL8411B |
| WiFi / WLAN IC | CNVI |
| Charging IC | MP2979A |
| Charger Architecture | Smart Battery |
| Card Reader IC | RTL8411B |
| Document Number | 6-7P-NL4C5-002 |
