compal la-a994p rev 0.1
This Compal LA-A994P Rev 0.1 motherboard, project code ZSO50, is built around the Intel Bay Trail M VCULC DIS platform with a VALLEYVIEW-M GPU supporting LVDS graphics. The board features a single 204-pin DDRIII-SO-DIMM slot for DDR3L 1333MHz memory in a single-channel configuration. The embedded controller is an ENE KBC9012, and the audio codec is an ALC3227. Networking is handled by a Realtek RTL8166-CG LAN controller, while a Realtek RTS5239 manages the card reader. The BIOS is an 8M SPI flash device.
A: The embedded controller is an ENE KBC9012.
A: The BIOS is an 8M (8 megabyte) SPI flash device.
A: The LAN controller is a Realtek RTL8166-CG.
A: The board has one 204-pin DDRIII-SO-DIMM slot supporting DDR3L 1333MHz memory in a single-channel architecture.
| Model | ZSO50 BayTrail-M |
| Project Code | ZSO50 |
| Board Number | LA-A994P |
| Revision | 0.1 |
| Date | 2014/05/26 |
| CPU Platform | Intel Bay Trail M VCULC DIS M/B |
| Document Number | LA-A994P |
| EC / KBC | ENE KBC9012 |
| Audio Codec | ALC3227 |
| BIOS / SPI Flash | BIOS (8M) |
| LAN IC | RTL8166-CG |
| Card Reader IC | RTS5239 |
| RAM Type | DDR3L 1333MHz |
| RAM Architecture | Single Channel |
| RAM Quantity / Slots | 204pin DDRIII-SO-DIMM X1 |
| GPU Type | VALLEYVIEW-M |
| Graphics Architecture | LVDS |
