compaq presario cq1-3100 arroyo pvt 715g4788m0g 20110427 1
This HP_PURISIMA_Ellsworth motherboard, manufactured by TPV (Top Victory Electronics Co., Ltd.) with board number 715G4788M0G revision M0G, is built on the AMD FT1 (Zacate FT1 413 BGA) platform paired with the AMD Hudson D1 (Hudson-D1 FCH 605 BGA) southbridge. The system integrates DX11 IGP graphics and supports single-channel DDR3 SO-DIMM memory across two slots. The embedded controller is an IT8519E, while the audio subsystem is handled by an ALC269Q-VB codec. Networking is provided by a Realtek RTL8175E-CG LAN IC, and wireless connectivity is supported via a half-sized mini card slot for WLAN. The main BIOS is stored on a 2MByte SPI flash ROM, with a separate 1MByte flash ROM dedicated to the EC. The board features a JMB389 card reader and an ANX3110 LVDS converter for display output.
A: The embedded controller is an IT8519E.
A: The audio codec is an ALC269Q-VB.
A: The main BIOS uses a 2MByte SPI flash ROM, and the EC has a separate 1MByte flash ROM.
A: The LAN IC is a Realtek RTL8175E-CG.
A: The motherboard supports single-channel DDR3 SO-DIMM memory across two slots.
| Brand | HP_PURISIMA_Ellsworth |
| Model | Ellsworth |
| Motherboard Manufacturer | TPV (Top Victory Electronics Co., Ltd.) |
| Board Number | 715G4788M0G |
| Revision | M0G |
| Date | Wednesday, April 27, 2011 |
| CPU Platform | AMD FT1 (Zacate FT1 413 BGA) |
| PCH / Southbridge | AMD Hudson D1 (Hudson-D1 FCH 605 BGA) |
| GPU Type | DX11 IGP |
| EC / KBC | IT8519E |
| Audio Codec | ALC269Q-VB |
| BIOS / SPI Flash | Flash ROM 2MByte |
| EC Flash / ROM | Flash ROM 1MByte |
| LAN IC | RTL8175E-CG |
| RAM Type | DDR3 SO-DIMM |
| RAM Architecture | Single Channel |
| Card Reader IC | JMB389 |
| WiFi / WLAN IC | mini card slot for WLAN (half sized) |
| HDMI Level Shifter | ANX3110 |
