Schematic Dell 3420 11282-1 Schematic
BrandDell / Vostro / Inspiron
ModelEnrico Caruso 14 MLK DIS
Project CodeInspiron: 91.4TY01.001 / Vostro: 91.4UA01.001
Board Number48.4TY02.0SC
RevisionX02
DateTuesday, January 03, 2012
Document NumberA31104
CPU PlatformIntel Ivy Bridge & Sandy Bridge
PCH / SouthbridgeIntel HM75 Panther Point BGA989
GPU TypeDiscrete (gDDR3 900MHz)
Graphics ArchitectureMuxless / UMA ONLY / Optimus solution installed
EC / KBCNuvoton NPCE885P
Audio CodecCirrus CS4213
BIOS / SPI Flash8MB Flash ROM
Charging ICBQ24707
Charger ArchitectureTI Charger
Power IC(s)ADP3211, TPS51216, TPS51125, TPS51219, RT8068, APL5916, VT1318+1323
RAM TypeDDRIII 1333/1600
RAM ArchitectureChannel A Slot 0, Slot 1 / Channel B
RAM Quantity / Slots2 slots (Channel A)
Thermal SensorNCT7718W
Card Reader ICRealtek RTS5138
LAN ICRealtek RTL8111F (Giga LAN) / Realtek RTL8105E-VD (10M/100M)
WiFi / WLAN IC802.11a/b/g Mini-Card WLAN+BT
This Wistron-manufactured motherboard, designated Enrico Caruso 14 MLK DIS with document number A31104 revision X02, supports Intel Ivy Bridge and Sandy Bridge CPU platforms paired with an Intel HM75 Panther Point PCH in a BGA989 package. The graphics architecture supports multiple configurations including Muxless, UMA ONLY, and Optimus solution with discrete gDDR3 900MHz VRAM. The system is managed by a Nuvoton NPCE885P EC/KBC and utilizes an 8MB Flash ROM for BIOS storage. Audio is handled by a Cirrus CS4213 codec. Power management includes a BQ24707 TI charger and multiple DC/DC converters from ADP3211, TPS51216, TPS51125, TPS51219, RT8068, APL5916, and VT1318+1323. Memory configuration supports DDRIII 1333/1600 across two slots on Channel A and a Channel B. Networking is provided by Realtek RTL8111F Gigabit LAN and Realtek RTL8105E-VD Fast Ethernet, with 802.11a/b/g Mini-Card WLAN+BT wireless connectivity. Thermal monitoring is handled by an NCT7718W sensor, and a Realtek RTS5138 card reader is integrated.
A: The motherboard uses a Nuvoton NPCE885P EC/KBC.
Q: What BIOS flash configuration is used?
A: The system uses an 8MB Flash ROM connected via SPI.
Q: What graphics configurations are supported?
A: The board supports Muxless, UMA ONLY, and Optimus solution configurations with discrete gDDR3 900MHz VRAM.
Q: What charging IC is used?
A: The charging circuit uses a BQ24707
  • Dell 3420 11282-1 Schematic.pdf
