Dell Alienware IPKBL-SC Schematic
This Pegatron IPKBL-SC motherboard, revision A00, is engineered for the Intel Kaby Lake platform with DDR4 memory support. The board utilizes an ALC3861-CG audio codec and an LAN_E2400 network controller. System management is handled by an SCH5553-UH EC/KBC. Power delivery is managed by a DELL PSU charging architecture using an RT8237E charger IC, supported by multiple power ICs including RT8068, RT8125H, RT3607, RT9624, APL5611, RT9045, and RT9025. Connectivity is provided by an ASM1142 USB hub controller and an ASM1543 USB-C controller.
Q: What is the project code and revision of this motherboard?
A: The project code is IPKBL-SC, revision A00, designed by Pegatron Corp.
A: The EC/KBC is an SCH5553-UH.
Q: What is the charging architecture of this motherboard?
A: The charging architecture is DELL PSU, using an RT8237E charging IC.
A: The audio codec is an ALC3861-CG.
| Brand | Pegatron Corp. |
| Project Name | IPKBL-SC |
| Revision | A00 |
| Date | Thursday, November 10, 2016 |
| Engineer | Justin_Lin |
| CPU Platform | Kaby Lake (IPKBL-SC) |
| PCH / Southbridge | Kaby Lake PCH |
| Audio Codec | ALC3861-CG |
| LAN IC | LAN_E2400 |
| EC / KBC | SCH5553-UH |
| Charging IC | RT8237E |
| Charger Architecture | DELL PSU |
| Power IC(s) | RT8068, RT8125H, RT3607, RT9624, APL5611, RT9045, RT9025 |
| RAM Type | DDR4 |
| RAM Architecture | DDR4 |
| USB Hub IC | ASM1142 |
| USB-C Controller | ASM1543 |
KABY LAKE PCH
ALC3861-CG
LAN_E2400
SCH5553-UH
RT8237E
APL5611
RT3607
RT8068
RT8125H
RT9025
RT9045
RT9624
DDR4
ASM1142
ASM1543
KABY LAKE PCH
ALC3861-CG
LAN_E2400
SCH5553-UH
RT8237E
APL5611
RT3607
RT8068
RT8125H
RT9025
RT9045
RT9624
DDR4
ASM1142
ASM1543
