Schematic Dell G5 5590 G7 7590 Pegatron VULCAN Coffee Lake-H Rev X00 Schematic
BrandPegatron Corp.
Project CodeX00Vulcan
Board NumberX00Vulcan
Revision1.0
DateWednesday, November 28, 2018
CPU PlatformCoffee Lake-H
CPU ModelIntel Processor
PCH / SouthbridgeHM370
GPU TypeNVIDIA/N18E-GX
Graphics ArchitectureMax-Q
EC / KBCMEC1416
EC/KBC PackageEC MEC1416
Audio CodecREALTEK/ALC3204
BIOS / SPI FlashSPI Flash (16MB)
BIOS Flash Exact ModelW25Q128JVSIQ
BIOS Flash ManufacturerWinbond
BIOS Flash Capacity16MB
Charging ICU3400
Charger ArchitectureCharger
Power IC(s)PU6900
RAM TypeDDR4
RAM ArchitectureSO-DIMM
RAM Quantity / Slots2
Card Reader ICRealtek RTS5144
USB Hub ICTI/SN1804044(TPS65982DD)
LAN ICQualcomm E2500V2
WiFi / WLAN ICM.2 WLAN KEY-E
HDMI Level ShifterDII AH1902-FA
This Pegatron X00Vulcan motherboard, revision 1.0, is built around the Intel Coffee Lake-H processor platform paired with an Intel HM370 PCH. The discrete graphics solution is an NVIDIA N18E-GX GPU configured for Max-Q architecture. The system firmware is stored on a Winbond W25Q128JVSIQ 16MB SPI flash IC. Embedded controller functions are handled by a Microchip MEC1416. Audio is managed by a Realtek ALC3204 codec. Memory configuration consists of two DDR4 SO-DIMM slots supporting up to 32GB at 2667MHz. The charging subsystem is controlled by IC U3400 with power management handled by PU6900. Networking is provided by a Qualcomm E2500V2 LAN controller, while a Realtek RTS5144 manages the SD card reader. USB-C connectivity is supported by a TI TPS65982DD controller.
A: The BIOS is stored on a Winbond W25Q128JVSIQ 16MB SPI flash IC.
A: The embedded controller is a Microchip MEC1416.
Q: What is the GPU configuration on this motherboard?
A: The discrete GPU is an NVIDIA N18E-GX configured for Max-Q architecture.
A: The motherboard uses two DDR4 SO-DIMM slots supporting up to 32GB at 2667MHz.
  • Dell G5 5590 G7 7590 Pegatron VULCAN Coffee Lake-H rX00 Schematic.pdf
